timlothian wrote:I did consider this much, however these fuel injectors aren't always your standard bosch, rochester....etc type fuel injector and as such, finding information about them is quite difficult.
As I've said before, the engine has relatively deep ports and in order to spray onto the back of the valves, and not all over the walls of the ports, I need an injector with a tight spray angle. The only injectors I have found at the moment with enough detailed information are the bosch injectors and as such I will be choosing one of these.
timlothian wrote:Randal, bringing up an old post!
With regards to the post, get a hold of Mark McCoy or any of the Motec guys. I have now graduated uni and so will not be organinsing one for our sae team.
With regards to the fuel injector. I did find one, cant remember whether I specifiec it above. The injector was a bosch one, as they are the only people who make available decent information. The injector had a 20 degree spray angle. If you look at the bosch-motorsport website you will find some good stuff!!
cheers
