AV inputs be assigned for other things?
Re: AV inputs be assigned for other things?
Postby Scott@FP on Tue Jul 16, 2013 11:40 am
You could possibly use an AV to set up the Gear Shift Force channel and shift cut via GSF. Be aware strain gauge amps go high voltage for one direction and negative voltage for the other, so Gear Shift Force based Gear Change Ign Cut is set up a little different, high or low would need to be disabled depending on which way you set up your switch on the AV, whether high or low voltage is 'turn cut on'.
Postby jasaircraft on Wed Jul 17, 2013 12:29 am
Thanks a bunch Scott! Ill be trying all of your suggestions in a few days once the car comes by...
jasaircraft
