MarkMc wrote:Looks like you may have a bit too much D once you get to 5th. You can see the duty cycle drop right off which gives you the drop in boost pressure. You then see the duty cycle go back up as the boost undershoots but the boost takes ages to recover, the duty looks like it has flat lined at the max allowable (about 65-ish%). You could need to have a bit more allowable duty cycle in fifth gear.
If you are using version 3 M800 software you can set everything as a table. Perhaps you need a gear position input into the ECU so you can tweak everything based on gear.
