Data down the CAN when an ecu has no logging enabled?
Re: Data down the CAN when an ecu has no logging enabled?
Postby Holmz on Fri Sep 23, 2011 11:43 pm
Chris Wilson wrote:OK, thanks Holmz, so how should I set the "Gain" column for reading Sats in Use and Sat Quality? Options in screenshot linked below.
http://www.gatesgarth.com/GDA/bits.png
I would start with the 8x1 (LSB) - but you would have to look at the output stream (RS232) for the GPS to be sure.
Or just disk around with it until you get 6-9 to show up.
Postby Chris Wilson on Sat Sep 24, 2011 12:10 am
OK the second option sounds good :) Thanks Holmz. But I think what is really needed is in here somewhere:
http://www.gatesgarth.com/GDA/satsinview.png
Not sure where the satellite quality data is coming from, it doesn't appear in any obviously named category in the GPS RS232 streams:
http://www.gatesgarth.com/GDA/strings.png
Chris Wilson
