by MarkMc on Mon Jun 07, 2010 9:45 am
A coil negative tacho is not like an ECU driven tacho so you cannot run them directly from the ECU. A coil negative side give a very large back EMF pulse that drive the tacho, an ECU driven tach works of a much simpler frequency drive from the ECU.
The way around this is to instal an iductive coil of some sort to provide the big back EMF spike you need for a coil negative tacho, we usually use a relay coil.
I have attached a basic wiring diagram
- Attachments
- COIL NEG TAC DRIVE.JPG (50.23 KiB) Viewed 10066 times
