making "ignition comp" work with DBW
Postby vprtech on Fri Jun 22, 2012 5:24 pm
I'm trying to get the "Idle Ignition Comp" table to work on a car this is using DBW. I know on throttle cable calibrations, a output channel must be assigned for a idle control valve for "Idle Ignition Comp" to work, even if a idle valve is not being used. Does this apply the DBW calibrations as well, or is there other enabling requirements that I have missed. I did set up the "Idle Ignition Comp" table with "Idle Air Error" as the axis, and the "Idle Aim RPM" target table. I've set all the idle parameters thresholds, but cannot get any sensor valve for IdleAEr . Any thoughts or ideas appreciated.
vprtech
Re: making "ignition comp" work with DBW
Postby Scott@FP on Sat Jun 23, 2012 5:08 am
Is aux 2 set up as "DBW Idle"?
Scott@FP
Users browsing this forum: No registered users and 35 guests
