Motec Boost control features ?
Re: Motec Boost control features ?
Postby Ben-S on Wed Oct 01, 2008 4:45 am
SportsCarRacer, I have run a boost control system on a restricted car similar in setup to what your doing and know how complicated that setup can get. I know it would add a lot to the thought process but if you have a dash you can use the math channels to turn 2 variables into one (using 1 less axis under boost control) or you can setup a "lookup table" in an available aux, inj, or ign output, once again eliminating an axis in your boost program. This can be repeated for as many axis as you need to free up (or until you run out of tables/channels)
Ben-S
Previous
Users browsing this forum: Majestic-12 [Bot] and 6 guests
