audi s2 ignition map
Postby racingaudi on Tue Jan 31, 2012 8:22 pm
Hi everybody!
Anyone who has a ignition map avileble for an audi S2 with 2,5bar boost, with a m800 box
Or a complet map that works ok.
Just so i have a better starting point.
For now it runns at 1bar but a wery safe ig map.
So if enyone could be able to provide one i would be glad.
Regards Peter J
racingaudi
Re: audi s2 ignition map
Postby stevieturbo on Tue Jan 31, 2012 11:09 pm
racingaudi wrote:Hi everybody!
Regards Peter J
You have given nowhere near enough details for anyone to even guess at a map for you. And given the boost level you mention, I doubt anyone would even risk trying even if you did give the full details of the build.
The only way to build a map for your setup, is through proper tuning. If the car already runs then you've already got through the hardest part of an install.
stevieturbo
Users browsing this forum: Google [Bot] and 33 guests
