Downgrade Firmware?
Downgrade Firmware?
Postby Frods on Fri Oct 28, 2011 8:19 am
Finally got the M800 connected after laying around for a few years now.
First got this message which makes sense:
But this one I am not sure about:
Ecu version V50.xx vs V3.53 ????
Still OK to continue?
Frods
Re: Downgrade Firmware?
Postby PaulGM on Fri Oct 28, 2011 10:23 am
Frods,
The software in your ECU is ancient and still DOS-based. It is giving you strange downgrade errors because it may not be able to make that much of a jump in software versions.
Try to go to version 2.33 first, and then upgrade to 3.53. If you cannot upgrade straight to 2.33, try upgrading to 1.6 first.
All of those packages are still available in the "Downloads" section of our website.
PaulGM
