Pure ignition cut input
Postby Mazi on Fri Sep 30, 2011 2:26 am
I can't find the way how to cut off ignition for infinite time via switch on digital or AT input.
Mazi
Re: Pure ignition cut input
Postby stevieturbo on Fri Sep 30, 2011 4:40 am
Mazi wrote:I can't find the way how to cut off ignition for infinite time via switch on digital or AT input.
If you need a basic cut like that, just put the switch in the power to the coils ?
stevieturbo
Postby Arve Flaat on Fri Sep 30, 2011 6:30 am
Hi
Use mode 3: Cut while signal is active.
Regards
Arve
Arve Flaat
Postby MarkMc on Fri Sep 30, 2011 2:28 pm
What do you actually want to do?
Postby Mazi on Fri Sep 30, 2011 11:23 pm
MarkMc wrote:What do you actually want to do?
At least two things.
First one is gearshift cut controlled by another source.
http://www.geartronics.co.uk/closedloop.htm
Second one is ignition cut caused by belt failure on external oil pump dry sump engine. I have a small electronic device capable to measure speed of oil pump and send it over CAN bus. An ignition cut table with RPM on X and Oil Pump RPM on Y will be fine. If it is not possible then fixed ratio between oil pump and engine RPM with percent of allowed difference with some filtering will be also fine. I know that this can be solved with "mode 8" ignition input, but I would like to prime the fuel pump before engine is cranking.
And I don't want to mess with relays.
Regards
Mazi
Postby Holmz on Sat Oct 01, 2011 11:42 am
Mazi
I would like the link to that please.
Holmz
Postby NeilW on Wed Oct 05, 2011 6:15 pm
You definitely need to use "mode 3" cut while active. However, you don't want a total ignition cut for gear shift - just a torque reduction, typically 85-90%
Neil Wallace (Geartronics)
NeilW
Users browsing this forum: Google [Bot] and 22 guests
