MarkMc wrote:The total time for the logging depends on your logging setup. The OEMs have 1Mb like the normal M800. If you log a lot of channels at high rates then you will have a short amount of logging time, if you log the same amount of channels at a lower rate the time is longer. The idea is to only log what you want, and each channel at a rate which is relevant to what you are doing.
