2jz Pressure Sensor
2jz Pressure Sensor
Postby eddies on Wed Mar 16, 2011 6:14 pm
Hi
I have installed a M600 in to my supra but i am having problems with the MAP sensor and the Lamda sensors would anyone know if the standard sensors on the Turbo will work with the ECU.
If they do and if anyone could let me know the Calabration and wiring, it would be a great help so i can check the standrd wiring diagram before i wire in.
Eddie
eddies
Re: 2jz Pressure Sensor
Postby Chris Wilson on Sun Apr 17, 2011 7:02 am
This should be a help. Andy Blyth is a fighter jet electronics engineer, and the type of fellow who only posts good first hand info. Hope it helps you.
http://www.mkivsupra.net/vbb/showthread ... resistance!
Chris Wilson
