Peak and Hold Settings
Postby Fast20b on Mon Dec 06, 2010 10:27 am
Hello
We have purchased an M800 ECU to run our Mazda 13B Two rotor Methanol engine previously tuned with a Microtech LT16 ECU with decen numbers achieving over 1100 HP at 46 lbs of boost. Now to our question
Complete setup
10 ID 2000 injectors with 2 on each primary wired in prallel = 4 total
3 on each secondary wired in parallel = 6 total
These injectors are 12 Ohm resistance and our voltage is 16V and fuel pressure 130psi
We are in need of the Peak and hold setting for these injectors?
Any help would be greatly apreciated.
Robert
SkernRacing
Fast20b
Re: Peak and Hold Settings
Postby SprinterTRD on Tue Dec 07, 2010 11:57 am
You dont need to set the injectors to Peak & hold. Just use 0 for the injector current.
You can press the f1 key in the software to read more.
SprinterTRD
Postby Fast20b on Tue Dec 07, 2010 2:42 pm
We tried 0 like the help section indicated and the injectors were maxed at 28psi. We have done over 55psi on a different ECU with plenty of fuel still left.
Thanks for the help I appreciate it
Robert
Fast20b
Postby stevesingo on Tue Dec 07, 2010 6:27 pm
Can you explain what you mean by Injectors maxed?
Do you mean that you could not add any more IjPW on the main fuel table?
Steve
stevesingo
Postby Fast20b on Sun Dec 19, 2010 12:03 pm
Yes thats exactly what I meant.
thanks
Fast20b
Postby stevesingo on Sun Dec 19, 2010 8:35 pm
Sounds like you need to change the injector scaling.
In the M800 software,
Adjust,
General Setup
Fuel
Setup
The injector scaling number refers to the IjPW in m/s that corresponds to 100 in the fuel main table. i.e set it to 10 and a value of 100 in the Fuel Main Table will give a 10m/s IjPW.
Whatever you have in the Injector scaling now I'd double it. When you press return after inputting the number you want, you will get a pop up window. Select yes in this window.
Steve
stevesingo
Postby Fast20b on Tue Jan 18, 2011 3:44 pm
Thanks Steve
Will be going back to the Dyno in about a week. Thanks for the help I will keep you informed of the results.
Robert
Fast20b
Postby MarkMc on Thu Jan 20, 2011 3:54 pm
Hi All,
Just noticed this one so sorry I din't get to it earlier. The ID2000s at not classically a high ohm injecotr becasue they are only about 8.5ohms and not 12-16. When using more than two on one injector output the current can get too high when using the "0" setting. So, using a different injector mode can help. If this is a drag car you can set the injector current to "-8" with a peak hold ratio of 4. Which should be fine.
Postby Fast20b on Tue Feb 01, 2011 6:13 am
Thanks for your advice. We tried that setup and did not have great results. Now we have two outputs with 4 inj P&H -10 and ratio of 5. It works but we have an issue with takeoff it wil go up to 30psi on the two step nand then it dies and opens up good. I attached the data log from racepak and teh motec ecu file.
Thanks for your help
Robert
attachments_2011_01_31.zip
ECU file and rcapak data log
(113.72 KiB) Downloaded 1560 times
Fast20b
Postby MarkMc on Tue Feb 01, 2011 7:49 am
You have to make sure the hold current does not go to 4amps or more, this will shut down the output. What happened when you used -8 with a PH of 4? What fuel pressure?
