Dual rpm error window
Postby Wolf_Tm250 on Mon Nov 01, 2010 3:23 am
anytime I press the clutch and hit dual rpm limit, I get an error window on my Car-PC that stays there until i press "OK" in the window:
any idea how not to get this error window anytime I am in those conditions?
Thank you.
Wolf_Tm
Toyota Celica GT-four ST205 - full TTE/WRC hardware
Parma - Italy
http://www.youtube.com/user/WolfTm250
Wolf_Tm250
Re: Dual rpm error window
Postby SprinterTRD on Mon Nov 01, 2010 8:22 pm
The error is displayed because dual rpm is active and you shouldn't tune a engine when it is active.
SprinterTRD
Postby Wolf_Tm250 on Tue Nov 02, 2010 3:29 am
SprinterTRD wrote:The error is displayed because dual rpm is active and you shouldn't tune a engine when it is active.
Ok thanks, makes sense.
So is there any way to remove this warning?
Thanks.
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby SprinterTRD on Tue Nov 02, 2010 8:15 pm
Yep, don't activate the dual rpm rev limit when you have the laptop connected!
SprinterTRD
Postby Wolf_Tm250 on Tue Nov 02, 2010 11:52 pm
SprinterTRD wrote:Yep, don't activate the dual rpm rev limit when you have the laptop connected!
Unfortunately this is not a solution...
I built a m400 permanent connected car-pc to have in dash gauges, so my "laptop" is always connected...
Wolf
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby SprinterTRD on Wed Nov 03, 2010 3:12 pm
I would sat that the warning is hard coded into the PC tuning software.
The only way to get around it is to possibly get the Telematry upgrade and use Telematry monitor for your display instead of the Tuning software.
SprinterTRD
Postby Wolf_Tm250 on Thu Nov 04, 2010 5:05 am
SprinterTRD wrote:I would sat that the warning is hard coded into the PC tuning software.
Ohh thanks!
Didn't thought about this opportunity...
Wolf
Wolf_Tm
Parma - Italy
Wolf_Tm250
