Huge RPM Limiter Problems
Re: Huge RPM Limiter Problems
Postby MarkMc on Thu Aug 12, 2010 5:03 pm
Interesting to look at the logging and check the time between rpm spikes, it looks to work out to be once per cycle...i.e. the rpm trace is showing you what is most likely to be happening on a single cylinder engine with (and I assume here) lots of compression and no rotating mass?
All yours Nathan. :)
Previous
