Crank ref sensor problem on m800
Re: Crank ref sensor problem on m800
Postby Mazi on Tue Jul 27, 2010 6:26 am
Mazi
Postby otto69 on Tue Jul 27, 2010 8:29 pm
Ok, if I wanted to upgrade
Would I......
1. Update the manager in the laptop to the latest version
2. Upgrade the UTC with it unplugged from the ECU
3. Upgrade the ECU
And hopefully it should work ??
Apart from the ref/sync capture mode, what other benefits would I see / use ??
cheers
Clayton
otto69
Postby Mazi on Tue Jul 27, 2010 8:50 pm
You can have both versions of software installed on your PC.
New UTC firmware will work with old version of ECU software also.
In the latest ECU Manager you will find (Help > Read me...) loooong list of changes from 2.3 version.
If you are not happy with new ECU software You can downgrade your ECU again.
Mazi
Postby otto69 on Wed Jul 28, 2010 9:13 pm
Cheers Mazi
Will give it a go and see what happens.
Clayton
otto69
Previous
