DBW and cruise control
Postby Daniel on Fri Jun 18, 2010 5:35 pm
Hey all
Is there any way to setup cruise control with the DBW on a M800?
Thanks Daniel
Danic Performance
Daniel
Re: DBW and cruise control
Postby IJ. on Fri Jun 18, 2010 7:33 pm
Went through this with the MoTeC Techs a few years back and there was no easy way to make the M800 do Cruise, I ended up using a Vac Motor to push on the top of my Modded pedal.
IJ.
Postby Daniel on Fri Jun 18, 2010 8:14 pm
Thanks dude will think about something like that.You running DBW?
Danic Performance
Daniel
Postby IJ. on Fri Jun 18, 2010 10:33 pm
Yep changed over a few years back when I was having a lot of trouble finding a TRAC strategy that would work on street tires and haven't looked back, it's a brilliant setup when run by the MoTeC as it allows you to tune any response curve you like so the car can be a docile kitten around town at low pedal %'s.
I piggy backed a late model Corolla pedal onto my stock one as this allows me to use the stock Cruise Control and bellcrank that actuates the top of the Pedal in my car, just got finished installing an aftermarket Controller and grafted the Vac motor onto the Front section that came with the car so it's an easy boltup as the stock control box had 0 adjustment and the car has changed somewhat in the last year or so ;)
IJ.
