Sr20DET Anti-lag....HELP
Re: Sr20DET Anti-lag....HELP
Postby edwin.opie on Mon Mar 08, 2010 7:23 pm
RossB on Fri Feb 06, 2009 9:45 am
There are a few options depending on how you want to run the Anti'-Lag and what the car is being used for. You can have the throttle open all the time and control the idle with an RPM limit or you can have a solenoid to open the throttle when the Anti-lag is active. I would at least make allowance for this when you build the loom. The other option would be to convert to DBW throttle.
hi ross,
could you explain what you described above? its interesting.. and i want to try it by open the throttle all the time and contorl idel with rpm limit. how much (%) of the throttle shoud be opened? could you give more detail info?
thanks
regards,
edwin
edwin.opie
Previous
Users browsing this forum: Baidu [Spider] and 12 guests
