driftshop wrote:Thanks for the feedback guys
Scott - thanks for picking that up. What should they look like can you please provide an example? They were on 1.6 version ECU software file that was upgraded to 2.3 and the values are in % and not degrees. So at 50 AT the timing will be retarded by 10% for that value (around 1.8 deg for at 250kpa). Does this sound ok?
Costa
Other items that seemed odd were the IJPU value of 10 ,seems high for a MAP comp'ed turbo car with a single set of injectors. v 3.x allows values of up to 400 in the fuel table so IJPU can be reduced further than previous versions, but can't remember which version had the increase to 400, if it was v2 to v3 or prior. Regardless if your table values and IJPU were the same it should run fine.
Typical IJPU setup for a 500ish cc/min injector would be 3 or 4, 1000-1200 2 or 3 on a 1:1 fuel MAP Comp and stay below 400 max in the table. No reason you can't use IJPU =10 but you gain main fuel table resolution with the smaller IJPU.
Fuel Decel may be messing with you, log fuel decel, if its active while running normally set all fuel decel parameters to zero. Accel/decel were one of the things changed from v2 to v3.
Firing order. Usually 1-5-3-6-2-4 (15 too young, 36 too old, 24 juuuust right) for inline 6's, but don't know for sure on your engine.
There's something somewhere messing with ya, look deep enough you'll find it.
Users browsing this forum: Majestic-12 [Bot] and 6 guests
