DC Servo Problems
DC Servo Problems
Postby Ben-S on Sun Feb 28, 2010 11:32 am
I'm having a problem setting up a servo motor on an M800. The problem seems to be the hi/lo setting under the sensor 0 menu. When the servo is at its highest position the current value is around 317. I can change the setting in the inputs screen so that the DC servo position channel reads 100 when all the way out and 0 when all the way in but it seems the ecu ignores that. Instead if I put a number in the table (50 as an example) it will move the servo until it reads 50 in the hi/lo table when in reality it's only at about 15.
Ben-S
Re: DC Servo Problems
Postby Ben-S on Wed Mar 03, 2010 2:42 pm
In case anyone else ever has this problem it turns out that you cannot run the servo position channel through any expander/dash because the hi/lo setting for the servo (and i would assume tps, stepper, etc) does not work through the can bus. Swapped the pin over to an ECU AV input and it worked great.
Ben-S
