Accel Advance
Accel Advance
Postby fetzi on Wed Dec 30, 2009 9:10 pm
has anyone a good description about the "accel advance" parameters?
i can't find any information and i am not sure if this parameters are necessary for
a good racing car.
thx.
best regards
fetzi
fetzi
Re: Accel Advance
Postby RossB on Wed Jan 13, 2010 9:33 pm
The parameters are similar to accel fuel. The clamp is the maximum amount of accel advance, the decay is the rat at which the advance returns to base timing in degrees per engine revolution. The sensitivity is the rate at which the advance is increased based on the rate of increase of the accel source (normally TP). The number in the table is basically a gain factor which is applied to the TP rate of change.
RossB
Users browsing this forum: Bing [Bot] and 12 guests
