M800 CAN bus protocol
Postby GMS Racing on Sun Jan 03, 2010 7:08 am
I have an M800 in my MINI JCW and want to connect it to a Race Technology (RT) data logger and display that I have. The RT kit can accept a CAN input and is configurable, so I need to know the details of the Motec CAN bus interface.
The RT program is fully configurable and I require the following information.
Device name e.g. RPM
CAN ID length - 11 or 29 bits
CAN ID
Filter location - None, 1 to Byte 8
Filter Value
Start bit - 0 to 63
Length bits - 1 to 32
Value type - Signed /Unsigned / Float (single)
Byte order - Intel Standard / Interl Seg / Motorola Forw LSB / Motorola Forw MSB / Motorola Seq / Motorola backward
Scale factor
Offset
Exponent (for time only)
Regards...
Gary
South Africa
GMS Racing
Re: M800 CAN bus protocol
Postby GMS Racing on Sun Jan 03, 2010 7:27 am
Also, I need to know the CAN baud rate - 1Mbit / 500Kbit / 250Kbit / etc.
Regards...
Gary
South Africa
GMS Racing
Postby figgie on Sun Jan 03, 2010 2:26 pm
GMS Racing
did you check the race technology Knowledge base?
http://www.race-technology.com/wiki/ind ... /MotecM800
that answers your question
what htis also means is that RACE TECHNOLOGIES recommends you use RS232 instead of CANbus.
figgie
Postby GMS Racing on Sun Jan 03, 2010 5:13 pm
figgie,
Thanks for your reply, yes I have checked the RT knowledge base but I want to get the CAN bus option working as it opens up a lot more projects for me in the future.
Regards...
Gary
South Africa
GMS Racing
