Blip?
Blip?
Postby alexflamingo on Tue Nov 03, 2009 5:44 am
Should you/he/she be us a function in the DBW or Ideal control that serves for lifting the number of turns in scaling when the pedal of the friction presses him, you/he/she should call Blip, do you know how to give me some information and as to shape him/it?
thanks
alexflamingo
Re: Blip?
Postby RossB on Fri Nov 27, 2009 9:20 am
Hi Alex,
Your post is a bit difficult to understand but I think you are asking about throttle blip when changing down gears??? You can do this if you have a downshift request either as a digital input or via a gear lever force channel. The setup for the throttle blip is configured in the Downshift setup which is found under Adjust/Functions/Gearshift.
RossB
Re: Blip?
Postby alexflamingo on Fri Nov 27, 2009 10:36 pm
Thanks for the answer, I/you/they have succeeded to find the solution. :)
alexflamingo
