can bus wiring
can bus wiring
Postby prostang on Fri Nov 20, 2009 6:40 am
hi i am about to make my wiring loom i an doing the can wire in 22g twisted wire it it ok to run this in the loom with the rest of the wiring
thanks
steve
prostang
Re: can bus wiring
Postby garychios on Fri Nov 20, 2009 12:59 pm
I would not. I had a lot of issues. My Professionally made harness also has the can wiring seprerat.
Also keep the CAN bus away from any Ignition boxes that create noise like M&W or Motec.
The can bus is extremly sensitive to Ignition noise etc. i spent days to only put my ignition box in the front left of the car and the ECU m800 in the passenger side rocker panel
garychios
Re: can bus wiring
Postby gregpe on Fri Nov 20, 2009 8:24 pm
I've made a lot of wiring looms and if CAN is away from high current wires in the same loom is ok, never had a problem.
separatly can loom is very fragile and is easy to damage it.
Just remember pair need to be twisted.
gregpe
Users browsing this forum: Bing [Bot] and 18 guests
