richib2002 wrote:Another useful one would be being able to increase or deacrease the highlighted area with the page up/page down keys, much quicker than the current "selecting a value for + or -" method
You can apply a simple +,-,/,* math to a selected area, it works better than incrementing in most cases, select your area with the shift+arrows, then say if you wish to increase by 5% key in [.95] at this point the 'direct entry' window pops up, then hit the [/] key.
You have to enter the numeric value first, then hit the math function key, for * and + you must use shift.
Before using this for the first time save the table as there is no ctrl-z
