By the way... I have purchase a Motec PLM and what option do I have to wire it in to M4 vs M400?
Cheers
Just a point to clarify.
All MoTeC ECUs will allow all Lambda functions to work (Quick Lambda, Wide Band Control) with the Lambda channel coming from an external MoTec source. All of our products have been designed by us with the same ideas so when we have a Lambda device talking to an ECU it is the way we figured it should work and is not based on any "Lambda Standard". If you hook up another brand Lambda meter it may not magically work, obviously the other company may have had completely different ideas about how the outputs should work. This has cought people out before and quite rightly people can't really expect to ring us up to sort out someone else's device, I think this is quite understandable.
Users browsing this forum: No registered users and 73 guests
