4 EGT's on an M800
4 EGT's on an M800
Postby garychios on Tue Sep 22, 2009 2:02 pm
I just cant figure out how you wire in 4 EGT's on the M800. The pin outs mentioned are no where to be found.
garychios
Re: 4 EGT's on an M800
Postby RossB on Tue Sep 22, 2009 3:00 pm
You will need to use thermocouple amplifiers and you can wire them in to any AT or AV input. When you say that "the pin outs mentioned are no where to be found" which pin outs are you referring to and where were they mentioned?
MoTeC Drawing # A03 refers to the Thermocouple Amplifier.
RossB
Postby garychios on Wed Sep 23, 2009 10:31 am
What would be the best course of action to do this? E888?
Also, the pin outs are mentioned in the software, but I might have mis-read it.
garychios
Postby MarkMc on Wed Sep 23, 2009 3:44 pm
Four EGT thermocouple amps will be cheaper than an E888 but you really have to ask yourself if you are going to end up adding more sensors in the future. With an E888 you get the 8 thermocouple inputs, 8 other Analogue channels and four digital. It really depends on how "full" your ECU is at the moment.
Postby garychios on Fri Sep 25, 2009 8:39 am
Where can I get thermocouple amplifiers. Or what is recommended?
garychios
Postby RossB on Fri Sep 25, 2009 9:08 am
You can get them from a MoTeC dealer. MoTeC part number 58008.
RossB
Postby garychios on Fri Sep 25, 2009 10:38 pm
Thank you. I missed that in the catalogue. :ugeek:
garychios
Users browsing this forum: No registered users and 67 guests
