Rpm drop on startline
Postby fetzi on Tue Aug 04, 2009 2:53 am
hello,
i have following problem.
when i start with dual rpm there is a rapid drop of rpm.
i attached the log file. may be someone can help.
thanks.
20090802-0350102.ld
(833.71 KiB) Downloaded 1120 times
fetzi
Re: Rpm drop on startline
Postby TunedByShaneT on Fri Aug 07, 2009 3:52 pm
I would turn the rise rate up from 4000 - in fact make it 0 so it becomes instantaneous. Then if you need rise rate control from there - you can start at 15000 and work backwards. It looks to me like the cut keeps happening after you dump the clutch and just kills the motor.
Regards,
Shane Tecklenburg
Technical Consultant
ST Consulting
21602 Surveyor Circle
Huntington Beach, CA 92646
714-318-5845
shaneteck@yahoo.com
TunedByShaneT
