REF/SYNC Filter for Evo 8/9?
Postby dv/dt on Thu May 28, 2009 2:36 pm
According to this Motec document
http://www.motec.com.au/filedownload.ph ... docid=1282
Filter values should be set to 1, but there is no information for Evo 8/9. Since it is optical in theory there should be no filtering, but just wanted to check what are some suitable values to use? Thank you.
dv/dt
Re: REF/SYNC Filter for Evo 8/9?
Postby RossB on Thu May 28, 2009 3:35 pm
Yes you will need filtering. Our V2.3 start file uses 1.5 for the ref and 0.5 for the sync.
RossB
Postby dv/dt on Thu May 28, 2009 5:03 pm
It seems v3.5 and v3.4 do not allow entry of values less than "4" for filtering. :shock:
dv/dt
Postby RossB on Fri May 29, 2009 9:33 am
Sorry, I thought from your question you were using 2.3. In V3.5 you have a table. You can use the following values:
Ref:
RPM Filter
0 124
500 124
1000 124
3000 80
6000 40
10000 24
20000 12
Sync:
0 124
500 124
1000 80
3000 24
6000 12
10000 8
20000 4
RossB
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
