I have a few questions for a project.
Suzuki 4x4 sj413 G13ba code engine,4 cylinder 8V 1300cc Single Point Injection with TBI.
They are a distributor cap and rotor. The distributor had one magnetic ref trigger sensor with four teeth (90°)
This engine had only this triggering.
This ecu can work with this SPI configuration engine? (4 cylinders four stroke, One injector,multi tooth)?
What are the right parameters to choose if it's right?
The OEM TBI (mikuni brand) injector is 1.6 ohms. It's better to add a resistor or can i control it directly?
Thank you very much.
Regards
