Crank trigger problem
Postby kevdachev on Thu Jul 03, 2025 4:52 am
Hi i have a M800 ecu which l use for my SBC drag truck. I have recently changed the engine for a GM LS engine. On the original SBC I used a MSD crank trigger system with four rotating magnets on the front pulley. This had a 2 pin connector plug (orange and blue wires) Now on the LS I have the 24x black sensor which is 3 pin. How to I wire the new sensor to work with the M800 system please.
Thanks Kev
kevdachev
Re: Crank trigger problem
Postby Stephen Dean on Thu Jul 03, 2025 11:36 am
Hi Kev,
The attached files should be able to assist in the wiring and setup of this sensor.
T03 Mixed Hall & Magnetic Sensors.pdf
(25.83 KiB) Downloaded 4 times
T01 Hall Effect Sensor General.pdf
(31.4 KiB) Downloaded 2 times
