False Air temp readings
Postby acca on Mon May 26, 2025 7:57 pm
Hello
I have a Bosch 0281002680 Tmap sensor that gives overestimated temperature readings of approx 5°C
it is connected to a M600 ECU on A9 A15 B3 and B16 pins.
I chose Bosch 2500Ohm Predefined calibration and tried the calibration table given on this page : https://www.motec.com.au/products/TMAP%20Sensor
Both overestimate temperature.
I tried two different sensors (same reference).
I don't understand where is the problem
acca
Re: False Air temp readings
Postby Stephen Dean on Tue May 27, 2025 10:09 am
Normally the Bosch TMAP sensors all use the same Temp sensor, but it looks like this model may use a different sensor that I do not have a calibration for.
What are you using for a reference temperature?
Postby acca on Wed May 28, 2025 2:10 am
A ctn 2,2k with resistor bridge.
acca
