M800 Pin Number
M800 Pin Number
Postby xuge on Thu Oct 31, 2024 11:07 pm
What does the Number after the Pin in the M800 Pin Number mean
xuge
Re: M800 Pin Number
Postby David Ferguson on Fri Nov 01, 2024 5:43 am
We need some context. Or an example...
It is probably the terminal location on the connector.
But it could refer to the enable code used to unlock features in the ECU. These are entered in the ECU Manager under Utilities->Enable ECU Options...
Re: M800 Pin Number
Postby Stephen Dean on Fri Nov 01, 2024 11:23 am
If you are talking about the Help | Pin Number list in the ECU Manager Help, then the number after the alphanumeric number is the matching pin number of the Autosport connector used with the M880.
Re: M800 Pin Number
Postby xuge on Sat Nov 09, 2024 12:32 pm
That's what I circled
xuge
