M800
M800
Postby xuge on Sat Oct 26, 2024 12:26 am
How does the ECU communicate with the VCU via CAN
xuge
Re: M800
Postby Stephen Dean on Sun Oct 27, 2024 4:34 pm
Which VCU? If it is an OEM VCU then you will need to do some custom CAN from the M800 to the VCU. However, due to the limitations in the CAN from the M800, you would be better off using a C125 or L120 as a CAN gateway between the M800 and the VCU. This will allow for custom CAN messages to be built in the C125 or L120.
Re: M800
Postby xuge on Wed Nov 20, 2024 10:05 pm
How do I export signal packets from the M800 to a DBC file
xuge
Users browsing this forum: Google [Bot] and 29 guests
