M880 10/12 cyl upgrade
Postby theexhaustman on Tue Nov 14, 2023 1:33 am
I have a V6. Currently on 6 coils & 6 injectors. I'm upgrading to 12 injectors.
I already have an IEX module and the relevant upgrade for the ecu. The IEX wiring is straightforward but what ecu settings need to be changed ?
I will be using Marelli IWP189 injectors for the additional 6 'shower' and the original Nissan for the lower set. I understand that ;
Ign output #1 > IEX
Injectors output #1,2,3,4,5,6 > lower original injectors
Ign #3,4,5,6 & Inj #7,8 for the upper additional injectors.
The question being; is there information on the settings to be changed in the ECU to enable this setup ?
Thank in advance. Andy.
theexhaustman
Re: M880 10/12 cyl upgrade
Postby Stephen Dean on Tue Nov 14, 2023 9:01 am
This should cover your needs.
Mx00 Secondary Injection Set Up.pdf
(901.42 KiB) Downloaded 396 times
