4g63 base map for m400 desperately needed
Postby monka on Tue Apr 07, 2009 8:38 am
right guys, bit of a dilema.
bit of a home project sitting in my garage, 1988 mitsubishi colt with a 4g63 transplant.
have been building it for a couple of years now, and just wanna get it going. i have just finished wiring in my m400, just need to get a base map/starter map on there so i can get it to another garage for the last couple of parts, and then to the tuners to get everything sorted out.
is it possible for a base map to be sent to me, just something to get it running, as i have noticed you can save and load files on there.
also what things do i need to set up, looking around have found the throttle position sensor needs doing, anything else?
also it has the full 4g63 set up, all the sensors etc are from it,
cheers guys
monka
Re: 4g63 base map for m400 desperately needed
Postby monka on Wed Apr 15, 2009 2:56 am
can no one help me?
monka
Postby monka on Fri Apr 17, 2009 6:43 pm
no one?
monka
Postby MarkMc on Mon Apr 27, 2009 11:05 am
Hi Monka,
Can you give me a bit more detail of which engine you have? There are a few differnt variations of that engine and the crank/cam trigger setup is completely different from version to version.
