Hi there
Would like to find out if the Motec M800 can be used on the above-mentioned vehicle, chassis code GRB.
The vehicle runs DBW and AVCS and has a control knob in the central console which is used as a map selector from factory to determine the vehicle responses.
Can the Motec integrate fully with the above-mentioned, with DBW and AVCS both active and map selection done from the factory knob?
Could you please provide the ECU-pinouts so that I can start working on the necessary PNP harness?
Thanks!
Cheers
Dennis
