m800 DBW settings, how long does it normally take????
Postby audi4u on Mon Mar 23, 2009 4:35 am
What tools are required to be able to characterize a dbw throttle body. The reason for the question, is that I have sent a thottlebody to a motec dealer to be characterized and its been ~ 3 months.
My project is on hold because of it and I am very frustrated.
Any help is appreciated.
Andre
audi4u
Re: m800 DBW settings, how long does it normally take????
Postby RossB on Tue Mar 24, 2009 1:56 pm
This can only be done by us here at MoTeC Research Centre or at MoTeC Europe. The correct settings are essential to achieve acurate throttle response and current requirements. In-correct settings could cause a dangerous failure. I would suggest that you contact your dealer and ask them to chase up the calibration for your motor.
RossB
Postby Ben-S on Sat Mar 28, 2009 7:55 am
It can be done by anyone with a good working knowledge of a drive by wire system. I have done 3 thus far with no issues and all my required vs actual tps logs look just like they should. I would imagine Ross is right though if you or your tuner didn't know how to properly set ALL the values I could imagine some pretty sketchy situations although I have never had anything bad happen. If it's really been 3 months you could have learned how to set one up 5 times over while you were waiting. I'm sure MoTeC's reason (just like any other ecu manufacture) for claiming only their research center can do it is liability.
Ben-S
Postby IJ. on Sat Mar 28, 2009 9:14 am
audi4u wrote:What tools are required to be able to characterize a dbw throttle body. The reason for the question, is that I have sent a thottlebody to a motec dealer to be characterized and its been ~ 3 months.
Andre
I may be reading the above bold part wrong but I take it that it's ALREADY at a Dealer and that it's been 3 months since it was sent in so maybe the Dealer has sent it to MoTeC.
IJ.
Postby RossB on Mon Apr 27, 2009 10:20 am
Ben,
There is more to characterising a DBW throttle than just making required TP and Actual TP match. We do not recommend that anyone attempt to do this themselves as this may lead to a failure of either the DBW or the ECU itself.
RossB
