by whrdnsx on Mon Oct 03, 2022 3:02 pm
Hello
Fitting new set of Bosch Motorsport Injectors 280 158 333 8.5ohms
Can someone help with correct M800 injector current Setup. do i calculate based on full Voltage 14V = 1.64Amps?
Peak hold ratio?
whrdnsx
by SOReilly on Mon Oct 03, 2022 4:10 pm
I have attached the customer datasheet for the injectors you are using.
Let me know if you have any questions.
- Attachments
0 280 158 333 Customer sheet.xlsx
- (166.9 KiB) Downloaded 493 times
SOReilly
- MoTeC
