Subaru EJ25(2011) Swapped Impreza WRX STi V8(2004) NO SYNC
Postby Kam on Fri Jul 08, 2022 7:47 am
I have a Subaru WRX STi V8 USDM (MY2004) Vehicle fitted with a Plug and Play MoTeC M800 (5 Plugs), but the engine is transplanted from a Subaru MY2011 2.5L;
It doesn’t have the front Camshaft (Sync) sensor, only the 2 rear camshaft position sensors
I get a REF Signal on Cranking and RPM, but no SYNC and no REF/SYNC indicator :evil:
The two rear Camshaft Position Sensors are of Hall Type 3 Wire
Which one should I use as SYNC and how to wire it into the MoTeC ?
Kindly
Thank You
Kam
Re: Subaru EJ25(2011) Swapped Impreza WRX STi V8(2004) NO SY
Postby Stephen Dean on Fri Jul 08, 2022 10:57 am
What is the trigger pattern on the crank, it should be the 36-2-2-2 and the Sync (Bank 2 inlet Cam pulley) is a 4-2 pattern. The Cam triggers will be 4 equally spaced teeth. For this to work, you need the Sync pattern to be read by the ECU, the CAM trigger alone will not work.
Postby Kam on Sat Jul 09, 2022 7:51 am
SDean wrote:Hi,
Thank You SDean,
I don't think this engine has a front cam pulley sensor on it, just the 2 rear sensors
Kam
