The switch input resources in M800 are by default in the configuration assigned to all of the AT resources, however they can be redefined as CAN messages.
If you go to Adjust > Digital Input Functions > SW Input n > Setup you can define the source of these items:
- Screenshot (44).png (1.72 MiB) Viewed 8821 times
Once you have assigned the source, you can pick appropriate channel:
- Screenshot (42).png (6.5 MiB) Viewed 8821 times
In the case of the ADL message format for your transmit from the dash, see the following:
- Mx00 Compound Message Receive (1).png (5.83 KiB) Viewed 8821 times
Just make sure you have the appropriate CAN Setup completed in Adjust > General Setup > Communications > CAN Setup. In the case of receiving messages transmitted from a Dash for use on the ADL resources in the M800, you need to ensure a CAN slot is set up appropriately:
- ADL Receive.jpg (77.63 KiB) Viewed 8821 times
You do not need to physically wire the resource, that is the point of CAN.
