M800 Subaru Can Messaging
Postby Vlad on Wed Sep 01, 2021 9:56 pm
Where can i find some details on this, this is a Subaru N14, and the M800 transmits coolant temp via can, from a custom data set to the oem cluster. I have a 2010 Forester on which i need to fit a M800, and i need to send coolant temp and rpm over can to the cluster.
Screenshot 2021-09-01 134224.jpg (44.06 KiB) Viewed 5014 times
Vlad Pescaru
Vlad
Re: M800 Subaru Can Messaging
Postby Stephen Dean on Thu Sep 02, 2021 10:00 am
Hi Vlad,
I have attached the installation notes for the WRX9-10 OEM replacement M800, if you can let me know the part number of the OEM ECU that was in the car I can see if we have a matching start file for it.
DVIN0014 M800 Plug-in to WRX 9-10 Installation Notes.pdf
(694.49 KiB) Downloaded 545 times
Postby Vlad on Thu Sep 02, 2021 9:58 pm
This car has a Goldbox M800. On the PNP one i saw the custom can messaging, and thought if i can do the same on this car, with the universal m800
Vlad Pescaru
Vlad
Postby Stephen Dean on Fri Sep 03, 2021 10:11 am
Hi Vlad,
I have sent you the files via PM.
