M600 Factory Reset
M600 Factory Reset
Postby pooh_bear on Mon Aug 23, 2021 4:23 am
Searched but couldn't find answer.
Quick question. Have bought a pre-owned M600. Have connected to it and taken a look round. Have also enabled an option i ordered.
Is it possible to factory reset (obviously not inc. the enabled options) the ECU?
Would make it easier to build a new config. instead of having to edit what's already there.
Thanks!
pooh_bear
Re: M600 Factory Reset
Postby NathanB on Mon Aug 23, 2021 9:34 am
there is no "factory reset" as such, however when you installed ECU manager, it comes with a config named Start.e35.
This is the base config you can use if starting afresh.
Postby pooh_bear on Tue Aug 24, 2021 7:32 am
Thanks Nathan
Found it and sent to ECU.
pooh_bear
