Ls1/L76 crank chopper wheel
Postby Daniel on Wed Jan 21, 2009 9:10 pm
Hi all
Just a quick question with the l76 chopper wheel do you use the mode 17 for this?
I am sure its 60teath missing 2.The cam will be the same ls1 one.
Thanks Daniel
Danic Performance
Daniel
Re: Ls1/L76 crank chopper wheel
Postby BLN355 on Wed Jan 21, 2009 9:39 pm
The L76 has a uses lumps on the timing sprocket to trigger the cam sensor when the LS1 Uses a ridge on the back of the cam, i would have thought they are a differnent type/size of pulse.
BLN355
Postby Martin on Wed Jan 21, 2009 9:58 pm
LS1 uses the special wiring and mode 23. Ref goes to REF and SYNC inputs. Sync goes to Dig1
I dont know the L76, but the LS7 uses normal wiring and Mode 17.
Crank Ref teeth = 60
Crip 440
LS7 Ref/sync Capture
Postby Daniel on Thu Jan 22, 2009 8:43 pm
Well the L76 crank just has a std chopper wheel that has 58theath and looks to be two missing.I will get a picture of it later on.
Daniel
Danic Performance
Daniel
Postby BLN355 on Thu Jan 22, 2009 8:58 pm
Whats the deal with the LS1 Ref Signal going to both the Ref and Sync in the M800?
BLN355
Postby Martin on Fri Jan 23, 2009 2:47 am
If you intend to run mode 23 then you need to wire as such
http://www.motec.com.au/filedownload.ph ... docid=1293
Postby Daniel on Fri Jan 23, 2009 7:13 am
Has it got something to do with the dumb chopper wheel the ls1 runs.
Danic Performance
Daniel
Postby MarkMc on Tue Feb 03, 2009 1:09 pm
Some ref/sync modes require a special way of reading the ref signal so you will find a few cars need the ref sensor wired to both the ref and sync inputs and the sync sensor wired to the digital 1 input. Yes, it is to do with the dumb chopper discs. :)
Postby Daniel on Tue Feb 03, 2009 8:51 pm
Hi Mark
The L76 uses a normal chopper wheel it has 58 teeth with missing two.
I will get some pictures soon.
Thanks Daniel
Danic Performance
Daniel
Postby MarkMc on Tue Feb 17, 2009 4:31 pm
The L76 is simply mode 17, 60-2 on the crank and 4 on the cam (two long, two short), its been around for many years.....even on the new Maserati V8's.
