Diff oil cooler and pump
Postby NickZ on Thu Jun 15, 2017 7:23 pm
M800 ecu
Ive fitted a oil cooler and electric oil pump to a diff.
there is a temp sensor on it connected to AV5 and is functioning and being logged be the ECU
I would like to control the pump from one of the outputs using the temperature from the sensor.
the sensor is setup as a user input on AV5 and called "Diff Pump"
in the Parameters of the outputs i can't find any way to associate the AV5 to it.
Is it possible to do what im trying to do or another way?
NickZ
Re: Diff oil cooler and pump
Postby Sean on Thu Jun 15, 2017 8:35 pm
Use the aux output to trigger a relay for the diff pump.....
You will need to determine the best parameters etc for your application.
Set the aux output to function 3 "Aux table"
Set the parameters for the table, for a diff pump probably a simple switch to ground something like this
aux paramaters example.jpg (25.36 KiB) Viewed 10635 times
Then setup the table something like this
aux table example.jpg (17.71 KiB) Viewed 10635 times
Sean
Postby NickZ on Thu Jun 15, 2017 9:08 pm
So the "AUX table 3" refers to AV3 for example?
for my setup i select "AUX table 5" ?
NickZ
Postby Sean on Thu Jun 15, 2017 9:18 pm
Aux table 3 is the setting for Aux output 3. In this case it is referencing User 5 .. If you have called the channel "diff temp" you make the x axis on the table "diff temp"
Sean
