Ref/Sync errors, but not on idle
Re: Ref/Sync errors, but not on idle
Postby Amigo_88 on Thu Sep 01, 2016 2:21 am
Now I will do it and hopfully the problems are gone...
Amigo_88
Postby Scott@FP on Sat Sep 10, 2016 5:45 am
There are many modern hall effect sensors that work just fine with small tooth profiles, high tooth counts, high RPM.
In many cases the ECU 1K 5v pullup may not be proper for a particular sensor, this can make the waveform bad, consult sensor mfg for output current requirements.
Scott@FP
Previous
