M800 and E888 - no communication
Re: M800 and E888 - no communication
Postby timo on Thu Aug 25, 2016 9:32 am
Ah ok, I thought there might be some hidden menu option to check the firmware version.
I run that tool and the progress bar appeared and it finished without errors so I think 2.07 is loaded on the e888.
Scott@FP wrote:Also keep in mind PWM 1,3,5,7 have different output properties than 2,4,6 and 8.
I' ve read that in the manual so I started my test with PWM2. At the end I had tested all PWM outputs of the e888 but they were all the same.
I'll keep on tryin'...
timo
Postby adrian on Thu Aug 25, 2016 9:42 am
Sorry I forgot to mention the transmit addresses are the base address plus 3. You should set your CAN 3 address to 251. Addresses are as follows:
Rx: 0x0F0 - Tx: 0x0F3
Rx: 0x0F4 - Tx: 0x0F7
Rx: 0x0F8 - Tx: 0x0FB
Rx: 0x0FC - Tx: 0x0FF
Postby Sean on Thu Aug 25, 2016 8:56 pm
timo wrote:I made a step into the right direction today thanks to all your help.
Nothing to do with me, that's all Adrian :roll:
Sean
Postby timo on Thu Aug 25, 2016 10:51 pm
E888 is fully working now. These are the settings which I use. Maybe this is helpful for someone else.
Sean wrote:Nothing to do with me, that's all Adrian :roll:
Sorry, I guess I muddeled up something there :oops: But thanks anyway, you also provided help.
adrian wrote:Sorry I forgot to mention the transmit addresses are the base address plus 3
Thank you so much for your time and your help Adrian! I really appreciate that. Thanks to you I can finally enjoy the benefits of the e888.
timo
Postby adrian on Fri Aug 26, 2016 10:40 am
No problems, I'm glad it's all working now.
Previous
