A flaky TPS can make the engine run bad by triggering accel fuel, log accel fuel parameters at max Hz, or alternately turn accel sensitivity waaaaay down in general setup/misc setup/ 'accel threshold' to max value and see if it helps. Sometimes the TPS can be a very fast fault that is hard to catch with lower speed logging. Same with MAP or any other sensor tied to fueling, check their signals if something goes awry
Sorry about the rising/falling confusion, I should have looked at your capture and not assumed. Hate scrolling over large pics. Even nudes
Notes for mode 28 ARE there. Keep scrolling. Hit 'OK' on '10+ OEM modes' as it scrolls down. The help F1 menus are pretty extensive, but sometimes not obvious.
Enabled options and serial number show up when you connect the UTC to the ECU, on the main screen before you open the ECU. Can be helpful in determining what you can and can't do.
