Ferrari F430 anyone?
Postby ElectronSpeed on Sat Oct 18, 2008 1:13 am
Has anyone done an Motec ECU on a Ferrari F430?
Are their any obvious pit falls before I give the customer a ballpark price? I am looking for the "You might not expect this but it requires you to make a new crank trigger wheel or the cams require . . . or the coils can't be fired twice per cycle and require an expander . . ."
thanks,
Eric Schieb
Electron Speed
ElectronSpeed
Re: Ferrari F430 anyone?
Postby Pascal on Sat Oct 18, 2008 12:14 pm
Dear Eric,
430 have same trigger as 360 so that should not be a problem. I know that there is one 430 with MM 131 with MoTeC. Dunno what did take to make it really work considering DBW and other "small" details. triple check before to jump out, for sure!
Kind regards Pascal
Pascal
Postby ElectronSpeed on Wed Oct 22, 2008 6:56 am
Pascal:>430 have same trigger as 360 so that should not be a problem.
Thanks.
Pascal:>triple check before to jump out, for sure!
That my goal.
Eric Schieb
Electron Speed
ElectronSpeed
