DBW Wiring
DBW Wiring
Postby Denali on Sun Apr 21, 2013 11:03 pm
wondering about how to wire the output from Aux1 and Aux2. the help says that Aux1 is the DBW control and Aux2 is used for idle control, my question is... is Aux2 basically disabled and internally the ecu is using the power from that output? or do i wire Aux1 and Aux2 together then to the negative of the DBW's motor? or some other way?
Denali
Re: DBW Wiring
Postby stevieturbo on Mon Apr 22, 2013 3:31 am
As far as I know, you cannot run DBW directly off a Mx00
You will need an external controller for the DBW unit.
Do you have this ?
http://www.motec.com.au/dbw4/dbw4overview/
stevieturbo
Re: DBW Wiring
Postby Denali on Mon Apr 22, 2013 7:48 am
i do not have the dbw4, i have the ecu upgrade at the bottom of the page here
http://www.motec.com.au/m400/m400upgrades/
Denali
Re: DBW Wiring
Postby Scott@FP on Mon Apr 22, 2013 12:08 pm
stevieturbo is not correct. You can run a single throttle body motor with no additional controllers, DBW4 is for multiple TB's, or in cases where you need to free up inputs. DBW will take up 4 AV's for the TPS sensors in the TB and the pedal.
Aux 1 and Aux 2 are motor + and motor - (TB specific about which goes where), if you want to use Idle Control you just enable it on Aux2.
Scott@FP
Re: DBW Wiring
Postby stevieturbo on Tue Apr 23, 2013 3:34 am
Wasnt aware of that.
Didnt think there would have been enough spare inputs for the ecu to do it all on it's own.
stevieturbo
Re: DBW Wiring
Postby Mazi on Fri Apr 26, 2013 1:38 am
Warning!
It is not possible to change AUX1/AUX2 polarity to reverse direction via output polarity setting.
AUX1 -->> NEGATIVE (-) side of motor
AUX2 -->> POSITIVE (+)
Mazi
Mazi
Users browsing this forum: Google [Bot] and 24 guests
